Easy on the caps, I can hear you.
The surface I refered to was the hub surface between the studs.[img:6a58df97c8]http://www.2carpros.com/forum/automotive_pictures/30961_hub_1.jpg[/img:6a58df97c8]
Not knowing what vehicle you have makes it a little tougher to help due to charactersics of some of them.
Thus this note before you posted.
[img:6a58df97c8]http://www.2carpros.com/forum/automotive_pictures/30961_note_2.jpg[/img:6a58df97c8]
If you have a grand cherokee I have seen dampner cause what you are describing, but from higher speeds typically.
[img:6a58df97c8]http://www.2carpros.com/forum/automotive_pictures/30961_dampner_1.jpg[/img:6a58df97c8]
Perhaps this is coming from rear rotors? That was why I asked of there was any difference whatsoever in the before and after effects.
Jan 21, 2007 at 10:29 AM
