Brake light question
JEEP CHEROKEE
MRGNUSENSE
My 1999 Jeep Grand Cherokee would not start yesterday. I lost all power..I checked my battery connection and found that my positive cable was a little loose and dirty. I moved it around a bit and tightened it up some and it started up just fine. Today I was on my way to work and someone told me that my right brake light was out. Does this sound related? Fuse problem or bulb? I've been told that I need to locate a 10 amp red fuse? Should I be checking the bulb before I go looking for the fuse? How can I tell if the fuse is bad once I locate it and is it difficult to remove the plastic caseing to get to the bulb?
THANKS!!
Oct 19, 2007 at 11:33 AM
2CARPRO JACK
  • 11,533 POSTS
If just one is out, im gonna go with bulb. If both were out I would say check fuses, but you have one working
Oct 19, 2007 at 11:34 AM
