95 Jeep Grand Cherokee funky problems ????????
1995 JEEP CHEROKEE
DATLMF
Hello, I have read some of your post and you sound like you could do me some good. I have a 1995 Jeep grand cherokee... started having some problems... slight hesitation when I shift from park to drive in the cold mornings, idles steady around 500-700 RPM's, occasionally when I come to a light and stop it will idle roughly down to about 250 RPM's and try to cut off - give her a little gas and she idles fine back up to 500 RPM's,or I can just put it in nuetral and then she still idles at about 500 but its real quiet and smooth but in drive it's a little rough and shakey. Now when I drive she cannot figure out if she wants to go into overdrive or not... going about 55-60 mph and it will shift overdrive and then back down then overdrive and back down continuously. I replaced the TPS sensor with no prevail...my engine light used to come on randomly but go off once I shut the jeep off and wouldn't come on again...finally it stayed on and I got the codes 12-32-24-55...I know 12 had to do with the battery being disconnected and 55 mean end of system scan. I am wondering if I need to replaced the MAP sensor or the PCM ? I really appreciate any help in the matter and thanks for just reading this long explanation of my problems !!!!!!!
Feb 7, 2007 at 8:31 PM
BRUCE HUNT
  • 3,754 POSTS
No, you should be fine. Not sure how the gas cap fits in here unless you know the code. Take it in, you should not hurt the car.
Feb 8, 2007 at 7:43 AM
