when I drive it, the brake light and abs light come on?
2005 JEEP CHEROKEE
14,500 MILES • 4 CYL • 4WD • MANUAL
AYSHA
every 10-15 minuets when i drive it, the brake light and abs light come on. i don't know what the problem is. can you help me please?
Nov 20, 2009 at 1:52 PM
SQM
  • 6,383 POSTS
The ABS light can come on for a number of reasons.
It could be due to a bad sensor in one of the wheels. Issues with the wiring or a loose connection somewhere. It can also be due to the ABS module.
To figure out what might be the issue, you will have to scan the vehicle and retrieve the ABS Code(s).
Here is a helpful video that shows how to retrieve the ABS codes:
https://youtu.be/rTtAnsOlZU4
The ABS module is located under the hood and there is one ABS/wheel speed sensor on each wheel.
I have attached diagrams for all those components and replacement procedures below.
Thank you.
Dec 14, 2021 at 11:40 AM
