2005 Grand 62K, A/C ONLY BLOWS ON HIGH
2005 JEEP CHEROKEE
RWHITTENBURG
Why would my A/C, heater, the entire thing - only blow when on high? Once I change the speed of the fan, the entire system turns off. No vent or air moving at all. This doesn't change if the actual AC is on or not. I've been told it's things from "something stuck in the fan" to a fuse...Could you point me in the right direction?
Sep 14, 2007 at 1:06 PM
GRICHARDS
  • 57 POSTS
Sounds like - "welcome to the club of blower resistor failure" - When your fan will only run on high, I would suspect the Blower Resistor assembly. Reason: My blower fan recently died and would only run on high, turns out that when the resistor assembly failed, the HIGH speed was the only one that would work as it was DIRECTLY connected to battery power and did NOT go thru any resistors to "absorb" voltage and make it run slower.
I suspect that when you drive at highway speeds, the blower doesn't actually blow, but you still get cooler air just from forced air flow from outside... My blower resistor assembly was located under the dash, passenger side, costs about $11.00 and is a simple fix...To all reading this post with a "runs on Hi only" symptom, this will be a good candidate for your problem!
I just jumped back and checked a previous post about the same problem, pls read "AC BLOWER" dated Wed 01Aug07, currently on page 3 of this forum - page will change as more folks log in and add...
Good luck and Please post results of check - we all learn from each other!
Sep 15, 2007 at 11:21 AM
