I have a whirring noise that seems to originate from the center of the dash that is pronounced when braking or turning right or on an uneven road when the suspension flexes. I assumed that the noise was coming from the front end somewhere so I changed the rotors and Pads as well as both sides wheel bearing/hub assy but still no good. The front differential has oil but I did notice that the drivers side axle mount was "wet". I checked the drive shaft and that is bone dry. The boot looked OK but I'm wonedring if I should take that off and re-pack the bearings in there as well
Nov 21, 2009 at 10:51 PM
