2004 Jeep Cherokee 4 wheel drive
2004 JEEP CHEROKEE
94,000 MILES • V8 • 4WD • AUTOMATIC
HFAY94
alright so i have a jeep and there are two shift knobs, 1 for park, neutral, reverse, lo, high, and one for the 4 wheel drive: 4wheel drive, neutral, and 4lo. when i try to put the 4 wheel drive shift into neutral so it isnt always in 4 wheel drive (to save gas mileage) it puts the whole care into neutral. is there anyway i can drive with the car in 4 neutal? should i try to go slow like 2 or 3mph and then put it in neutral and try to drive? the book says to do that but it doesnt work
Jan 18, 2010 at 9:40 PM
PAT-XJ
[quote:79a691e4b5="hfay94"]Transmission problem
2004 Jeep Cherokee V8 Four Wheel Drive Automatic 94000 miles
alright so i have a jeep and there are two shift knobs, 1 for park, neutral, reverse, lo, high, and one for the 4 wheel drive: 4wheel drive, neutral, and 4lo. when i try to put the 4 wheel drive shift into neutral so it isnt always in 4 wheel drive (to save gas mileage) it puts the whole care into neutral. is there anyway i can drive with the car in 4 neutal? should i try to go slow like 2 or 3mph and then put it in neutral and try to drive? the book says to do that but it doesnt work[/quote:79a691e4b5]
To put it in 2wd you use the small leaver on the left hand side it should say forword as far as it will go = 2wd-H -4wd- H and 4wd-L its best to do this when your jeep is moving but not to fast 20mph
Jan 31, 2010 at 8:45 AM
