2003 Jeep Cherokee Turn signal and blower motor
2003 JEEP CHEROKEE
126,000 MILES • 6 CYL • 4WD • AUTOMATIC
HART729
At the same time I lost my turn signals and my blower motor, I checked all the fuses and all are good. I thought it may be the flasher but that wouldn't explain the blower motor. Don't know if it would be a power relay?
Mar 10, 2009 at 10:50 AM
BUICKRODGUY88
  • 8 POSTS
i'm not sure why both would go at same time but for the blower motor before you bought another try this with your jeep running or switch on go to the passengers side under your hood to where the blower motor is mounted in the firewall and find the plug the is the it's possible this is loose i've had an issue where i changed it thinking it was blown but turns out i spend 35 bucks on a used motor for no reason. hope it's something simple like that
Mar 11, 2009 at 11:45 PM
