2003 Jeep Cherokee Idle at start up 2003 GrandCherokee Lare
2003 JEEP CHEROKEE
88,500 MILES • 6 CYL • 4WD • AUTOMATIC
EDEPALMO
  • 4 POSTS
Sometimes at start up of Engine at least 50% of the time.The Engine Idle speed at start up is 2000 RPM or a little above.
If you turn the ignition off and restart it will be at the normal Idle of around 1500 RPM
I have changed the Idle positioning sensor twice, still have the same problem
Feb 9, 2010 at 10:23 AM
Has the check engine light come on? Have you checked for vacuum leaks?
Feb 10, 2010 at 1:03 AM
EDEPALMO
  • 4 POSTS
Joe No the check engine light is NOT on. I've checked for Vacuum leaks,but found none yet
Feb 10, 2010 at 7:35 AM
EDEPALMO
  • 4 POSTS
[quote="Jacobandnickolas"]Has the check engine light come on? Have you checked for vacuum leaks?
Jo
No check engine light isn't coming on. I have checked for vacuum leaks. Have not found any.
Feb 10, 2010 at 8:06 AM
I feel there is a problem with the throttle position sensor, but I can't be sure without a trouble code.
Feb 11, 2010 at 4:02 PM
EDEPALMO
  • 4 POSTS
Joe; The Service Engine light is not on. Put tester on and can't get any codes at all. In my original post I said I replaced the Idle positioning sensor twice. I meant I replaced the Throttle positioning twice. It still does the same thing.
Feb 11, 2010 at 10:24 PM
If there is no check engine light, you replaced the TPS, then my guess is a vacuum leak (I realize you checked) or a temp sensors, or a fuel pressure issue.
Please bear with me. I'm not there and without the check engine light, it becomes a guessing game until the problem is located.
Feb 11, 2010 at 10:32 PM
