2003 Jeep Cherokee cooling fan will run until the battery is dead?
2003 JEEP CHEROKEE
LANCE420
Electrical problem
2003 Jeep Cherokee V6 Two Wheel Drive Automatic 65000 miles
the cooling fan even after ignition is off the fan will run until the battery is dead, what should i check and where is the cooling fan module located at?
Dec 6, 2007 at 3:00 PM
Inspect and test the hydraulic cooling module at right front of engine compartment and also the radiator fan relay. see below
https://www.2carpros.com/forum/automotive_pictures/12900_fan_relay_1.jpg
Dec 6, 2007 at 3:45 PM
Your cooling fan relay is sticking on which is right below the right headlight, here is the location and I found the cooling fan wiring diagrams so you can see how the system works with the relay location in the images below. It is not a typical relay, but more like a solid state speed control. Check out the images (below). Let us know if you need anything else.
Jul 5, 2024 at 5:30 PM
