2002 jeep grand cherokee limited
2002 JEEP CHEROKEE
AICRAFTTECH1
ok lets see i should start by saying that there is a rubbing noise coming from the jeep when turning, sounds a lot like a tire rubbing a wheel well, however this is not coming from the front end sounds like the rear end is where the noise is coming from, maybe from the center?
ive looked everwhere around both front and rear tires and suspension parts looking for sighns of wear and tear, unusual rub marks, the tires look great no sighns of rubbing on the inside or the outside of the tires or any parts that might be within touching distance.
this noise does not happen everytime you turn however it does happen while you are turning left or right, and it seems that time, temp amount of load im carrying has no effect on whether or not it happens.
the drive shafts show no sighns of damage nor does the transfer case, the rear end looks great no sighns of damage everywhere ive looked shows no sighns of wear or tear leaking fluids everything looks great and how you would expect a clean and well maintained car should look.
well i cant think of anything else to say but im lost as to where to look for possable problems involving this issue whith the rubbing noise.
any suggestions would be appreciated.
sincerly michael mitchell
Apr 14, 2007 at 4:42 PM
MERLIN2021
  • 17,250 POSTS
You say the drive shft looks great did you check for play in the U-Joints?
Apr 15, 2007 at 11:02 AM
