2002 Jeep Cherokee Idle air control valve or vacuum leak???
2002 JEEP CHEROKEE
98,000 MILES • V8 • 4WD • AUTOMATIC
RARMBRI
Recently I have started having problems with my jeeps starting RPMs. Normally it starts and peaks at about 1350 RPM and drops fairly quickly to about 850 RPM. Lately the starting RPM is about 2000 and as it comes to idle the engine races and RPMs will fluctuate erratically. Every so often it acts like its not getting any air and doesn't want to start. While in motion the RPMs continue to swing about 150-200 but not quite enough for the transmission to shift. Do I have an IAC valve problem?
Thanks in advance.
Oct 20, 2008 at 12:59 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:bd85be6fc0="rarmbri"]Engine Performance problem
2002 Jeep Cherokee V8 Four Wheel Drive Automatic 98000 miles
Recently I've started having problems with my jeep's starting RPMs. Normally it starts and peaks at about 1350 RPM and drops fairly quickly to about 850 RPM. Lately the starting RPM is about 2000 and as it comes to idle the engine races and RPMs will fluctuate erratically. Every so often it acts like its not getting any air and doesn't want to start. While in motion the RPMs continue to swing about 150-200 but not quite enough for the transmission to shift. Do I have an IAC valve problem?
Thanks in advance.[/quote:bd85be6fc0]
First take off the IAC and clean it. It just may have some build up. Then check for vacuum leaks, cracked hoses etc.
Oct 21, 2008 at 9:39 PM
