How do I check lifters?
I've been experiencing a 'ticking'noise and it finally came to a head the other day. The noise doesn't go away with speed or time, but does increase as the gas pedal is pushed.
I've pulled the valve cover, ignition coil and the spark plugs (based on Haynes), but i don't know what symptoms to look for. I am going to check the clearance, but the manual isn't as detailed as I'd like for it to be on this topic.
If this doesn't sound like the lifters, what should I check instead?
Aug 19, 2009 at 12:45 PM
