2001 Jeep Cherokee engine runs hot when in traffic or at re
2001 JEEP CHEROKEE
101,000 MILES • 6 CYL • 4WD • AUTOMATIC
J.T.MARTIN
my water pump, electric fan module and sensor,themostat,wpper and lower raditor hoses have all been changed
Oct 18, 2008 at 4:03 PM
JNOVACK
  • 723 POSTS
check that the cat is not cloged that can cause that issue also and do you have any codes
Oct 18, 2008 at 5:28 PM
J.T.MARTIN
what is cat that if clogged will cause overheat problem in 2001 grand cheerokee 6 cyl
Oct 18, 2008 at 7:17 PM
JNOVACK
  • 723 POSTS
Catalytic Converter causes back pressure and will and over heat problem
Oct 18, 2008 at 7:48 PM
