2001 Jeep Cherokee CODE PO306
2001 JEEP CHEROKEE
70,775 MILES • 6 CYL • 4WD • AUTOMATIC
RFITZ
I SCANNED MY CHECK ENGINE LIGHT, CODE COMES UP PO306 #6 CYLINDER MISS FIRE. I REPLACED MY COIL RAIL .THIS DID NOT SLOVE THE PROBLEM .I CHECKED FOR PULSE SIGNAL AT THE INJECTER. IT HAS IT. I HAVE 150PSI COMPRESSION IS MY ECU BAD. WHAT ELSE COULD POSSIBLY CAUSE MY MISS FIRE PROBLEM.
Jan 19, 2009 at 5:25 PM
BMRFIXIT
  • 19,053 POSTS
Did u replace the spark plug
and if not you should
also check if the new coil working (firing )
if not check wiring and connector
ohm the injector
Jan 19, 2009 at 5:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Possible causes for this code are: defective Camshaft Position sensor, deftective Crankshaft Postion sensor, improper valve timing, vacuum leak, defective ignition system, fuel contamination, improper fuel pressure or capacity, spark plugs, accesory drive belt, or defective fuel pump.
Did you check your spark plugs to ensure #6 is receiving proper spark and is not fouled?
