2000 Jeep Cherokee Water in Oil
2000 JEEP CHEROKEE
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
LAKK
2000 Cherokee XJ 4.0L V6: overheated, rebuilt head (mag'd and pressure tested ok). Put rblt head back on and runs well but now water in oil. pulled head and had it checked again; still ok. Gasket appears to have good compression marks indicating good seal. Did not put locktite on #11 bolt though... could that have caused this? anything else besides cracked block?
May 20, 2010 at 3:40 PM
Notes REMOVAL PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/12900_b1_4.gif
Release the parking brake. Raise and support the vehicle. Remove the rear tire and wheel assembly from the vehicle. Remove the drum. If the drum does not remove easily, then complete the following steps: 5.1. Remove the rear brake adjuster access hole plug. 5.2. Insert a screwdriver through the hole in the backing plate. Hold the brake shoe adjuster actuator away from the park brake lever strut. 5.3. Reduce the brake shoe adjustment by turning the park brake lever strut with another screwdriver. 5.4. Remove the drum.
https://www.2carpros.com/forum/automotive_pictures/12900_b2_2.gif
If the drum is rusted or corroded to the hub and the backing plate, then complete the following steps: 6.1. Insert 2 bolts in the 2 holes of the drum. 6.2. Turn the 2 bolts at the same time in the clockwise direction in order to loosen the drum from the backing plate. 6.3. Remove the drum. Inspect the drum. Refinish or replace as necessary. Inspect the brake shoes and the drum brake components. Replace parts as necessary. INSTALLATION PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/12900_b3_3.gif
Install the drum. Install the tire and wheel assembly to the vehicle. Lower the vehicle. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
May 20, 2010 at 7:14 PM
