Hi, if your saying, the starter cranks good,but, the vehicle won't start, Have a helper crank it while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure.
To check for spark, you can pull a plug wire, stick known good plug or spark tester in the boot, ground metal part of plug/tester to metal part of engine. Watch for spark, engine cranking.
Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. You can call them and ask?
Mar 24, 2010 at 9:22 AM
