2000 Jeep Cherokee Squeaking belt
2000 JEEP CHEROKEE
166,000 MILES • 4 CYL • 2WD • AUTOMATIC
HONEHE
Vehicle begins to squeak while driving after warming up. Does not squeak on initial startup or first few minutes of drive. Noticed crankshaft pulley is wobbling.
I've replaced: belt, power steering pump and pulley, idler pulley and pulley that bolts directly to engine.
February 24, 2008
BMRFIXIT,
Thanks for the info.
I wasn't sure what you meant by the pulley being in two pieces but now understand. There is a thin rubber ring on the outer edge of the inner pulley and the inner pulley/rubber ring is inserted into a larger pulley all of which is called the vibration damper. I'll purchase one and install and let you know how it goes.
Thanks.
Feb 21, 2008 at 7:44 PM
BMRFIXIT
  • 19,053 POSTS
you said it
check the crank pulley
it like motor mount
its two pieces
and it can be fault
good luck
Feb 21, 2008 at 10:56 PM
