2000 Jeep Cherokee power door locks
2000 JEEP CHEROKEE
STEVECHI
Electrical problem
2000 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
when locks are engaged all door locks work, but front door locks make a werring sound after engagement the same thing happens when unlocking . reading the jeep manual i have they suggest it may be a faulty relay, but i can"t seem to locate a relay for the power locks I have check the main fuse box under the hood and the fuses in the drivers footwell .would appeciate any help in this matter
Jan 25, 2010 at 6:44 PM
CYBER TECH
  • 23 POSTS
The locks are making that noise because the little motor that locks the door is worn out. These motors are built into the door latch, so you will need to replace the latch.
Jan 26, 2010 at 5:55 PM
