2000 Jeep Cherokee Moaning Brakes
2000 JEEP CHEROKEE
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAMWISMER
While parked or at a stop, when I press my brakes I hear a moan. It happens with a specific amount of pressure. I can make it stop by reducing the amount of pressure. It has been going on for about 6 months or so. I figured the system needed bleading. I just replaced the front pads and rotors and blead the system and it actually seems a bit worse. Also, the peddle is still a bit mushy and I wonder if I blead the system well enough. What could be causing the moan?
May 21, 2009 at 9:58 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Sound is coming from brake vacuum booster. as for pedal rebleed should do the trick. Have someone apply brake give a listen to booster.
Let me know
Thanks for donate
May 21, 2009 at 10:03 AM
SAMWISMER
Thank you for the reply I will give that a try. What is the best procedure for bleeding the brakes if I can only access one wheel at a time? Do I need to bleed from all for bleeder valves?
May 21, 2009 at 10:12 AM
DOCFIXIT
  • 18,828 POSTS
Start with right front then left. backs should be good if they where not opened.
May 21, 2009 at 10:38 AM
