The blower motor is either under the dash on the passanger side of the vehicle or under the hood (firewall) on the passanger side.
1.If the vehicle is equipped with air conditioning, recover the refrigerant from the refrigerant system.
2.Disconnect and isolate the battery negative cable.
3.If the vehicle is equipped with air conditioning, the accumulator must be relocated in order to service the blower motor. This is done by loosening the accumulator retaining band screw and disconnecting the accumulator inlet tube from the evaporator outlet tube. The accumulator can then be moved far enough to access and remove the blower motor.
4.Unplug the blower motor wire harness connector.
5.Remove the three screws that secure the blower motor and wheel assembly to the heater-A/C housing.
6.Rotate and tilt the blower motor unit as needed for clearance to remove the blower motor and wheel from the heater-A/C housing.
Fig. The blower motor installation on the Cherokee
To install:
1.Align and install the blower motor and wheel assembly into the heater and A/C housing.
2.Install and tighten the three screws that secure the blower motor and wheel assembly to the heater-A/C housing. Tighten the mounting screws to 20 in. lbs. (2.2 Nm)
3.Plug in the blower motor wire harness connector.
4.If the vehicle is equipped with air conditioning, connect the accumulator inlet tube to the evaporator outlet tube and tighten the accumulator retaining band screw.
5.Connect the battery negative cable.
6.If the vehicle is equipped with air conditioning, evacuate the refrigerant system.
7.If the vehicle is equipped with air conditioning, charge the refrigerant system.
1.Disconnect and isolate the negative battery cable.
2.Remove the instrument panel silencer from the passenger side of the instrument panel.
3.Remove the glove box from the instrument panel.
4.Disconnect the blower motor wire harness connector from the blower motor power module or resistor , depending on how equipped.
5.Remove the three screws that secure the blower motor to the HVAC housing .
6.Remove the blower motor from the HVAC housing.
Fig. View of the blower motor (housing removed) on the Grand Cherokee
To install:
1.Position the blower motor into the HVAC housing.
2.Install the three screws that secure the blower motor to the HVAC housing. Tighten the screws to 20 inch lbs. (2.2 Nm).
3.Connect the wire harness connector to the blower motor power module or resistor, depending on how equipped.
4.Install the glove box into the instrument panel.
5.Install the instrument panel silencer onto the passenger side of the instrument panel.
6.Reconnect the negative battery cable.
Jun 26, 2009 at 1:22 PM
