2000 Jeep Cherokee cuts out when driving
2000 JEEP CHEROKEE
PAULKELLY196161
2000 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
it cut out when i was driving had to wait 10 min, then restarted it again
Dec 1, 2009 at 2:37 PM
JOSECORONADO
I had the same problem.. you can make a simple test to verify if is the crankshaft sensor.. this is a common problem in 4.0 engines. this is going to sound dumb but it works,,, when your engine cuts off,, get a bottle of water and pour directly to the crankshaft sensor,, this is located between the engine and the transmission.. right next to the firewall.. this will help to cool down the sensor and the engine will start inmediatelly.. you can find the sensor in any autoparts..just make sure to take the old sensor because there are several types. I hope this was helpful for you.
Dec 2, 2009 at 10:45 PM
