2000 Jeep Cherokee AC AND HEATER CORE HOUSING
2000 JEEP CHEROKEE
14,000 MILES • 6 CYL • 4WD • AUTOMATIC
CTHOMAS45
I'M REPLACING MY EVAPORATOR AND HEATER CORES AND I HAVE THE DASH OUT AND ALL THE HOUSING SCREWS OUT AND THE HEATER CORE TUBES OFF BUT I'M HAVING A PROBLEM GETTING THE EVAPORATOR TUBES DISCONNECTED AND I'VE TAKEN OFF THE AC TUBE CLAPS ALSO BUT THE 2 TUBES ARE NOT COMING APART. DO YOU HAVE ANY SUGGESTIONS BECAUSE THE TUBES ARE KEEPING ME FROM PULLING OUT THE HOUSING FROM THE INSIDE OF THE JEEP
Jun 26, 2010 at 9:10 AM
CARADIODOC
  • 34,306 POSTS
Hi cthomas45. Welcome to the forum. Those clips are just insurance so the real latches don't come apart. There is a spring that must be collapsed inside the connector. A special tool is needed for that. The most common style is a hinged two-piece that folds around the tube, then you press it into the connector to release the spring, and pull the tubes apart. The other version looks like two sticks connected in their centers with a rivet. On each end of each stick is half of the tool. You choose the correct size for your tube then swivel each half over the connection and pull it into the spring to release it. The other end of the sticks has the tool for a different size connector, and if you look at the other side, there are two more different sizes; four in all.
Just to double-check, you do have the refrigerant sucked out, right? It sounds like you know what you're doing, but it doesn't hurt to ask. Escaping refrigerant will freeze eyeballs and cause frostbite. If you don't wear safety glasses, or better yet, a face shield, no's the time to start.
Here's a link to the Mac Tools page with the first tool I mentioned:
http://www.mactools.com/productdetails/tabid/119/c-22807-ac-service-tools.aspx
It's the second from the bottom of the page and shows a kit for four different size hoses. I didn't see the less expensive second tool I mentioned.
caradiodoc
Jun 26, 2010 at 1:46 PM
