1999 Jeep Cherokee WILL NOT CRANK
1999 JEEP CHEROKEE
134,000 MILES • 6 CYL • 4WD • AUTOMATIC
WILLIAM070
I HAVE NEVER HAD ANY PROBLEMS WITH THE CAR. I TURNED THE KEY AND ALL LIGHTS ARE WORKING BUT IT WILL NOT CRANK. THERE IS NO CLICKING SOUND OR EVEN A SINGLE CLICK. THE ENGINE JUST DOES NOT TURN OVER
Sep 20, 2008 at 12:52 PM
BLACKOP555
  • 10,386 POSTS
first thing i would be doing is checking if the neutral safety switch is good or not, also i would check to see if the battery is charged.
if those both are good next step would be to check if the starter relay is getting the signal from the ignition switch to crank.
Sep 20, 2008 at 5:42 PM
