WE just bought this jeep from our son and we are the third owners. it was very well taken care of and is for the most part, in great shape. However, the transmission will not shift from second gear to drive until the rpm is between 3000 and 3500 until warm. After it is warm it will shift at around 2800rpm.
Transmission seems to run normally except when shifting into high gear. Bought with check engine light on,changed output speed sensor on transmission and check engine light is now off. I am leary to take it to a transmission garage. I believe they would automaticllay say it needs a rebuild and I do not believe that is the case.
I do not know if the transmission fluid and filter has every been changed. Thanks for your help.
Jan 13, 2009 at 8:26 PM
