1999 Jeep Cherokee Serp Belt squeels - AC - Defrost
1999 JEEP CHEROKEE
115,000 MILES • 6 CYL • 4WD • MANUAL
THOSEGUYS26
My serpt belt is about 4 months old. I just got done replacing the water pump, starter, tension pulley wheel, & thermostat as well as flushing the radiator. My problem is, at start up I get a quick squeal from the belt for about 3 seconds and then it stops. The only time it comes back instantly is when i turn the ac on or the defrost fan. Is my belt just loose or not properly on or is my ac unit or something else gone? Thanks!
Jan 31, 2010 at 4:51 PM
THOSEGUYS26
Well, I just did a little playing with the tension screw and basically tightened a bit, started it to test the squeal and repeated until squeal was gone. WHew!
Jan 31, 2010 at 6:04 PM
