1999 Jeep Cherokee Key attachement stopped working
1999 JEEP CHEROKEE
135,000 MILES • V8 • 2WD • AUTOMATIC
CHERNANDEZJEEP
Pretty much my electric locks don't work anymore. when I hit the switch to lock all the doors it won't do anything but when I unlock it. it works. the key attachment that locks and unlocks the doors went too when this happened, replaced the battery for it still dosen't work
Feb 1, 2010 at 8:40 PM
You need to check the main switch on the driver's door. Check to see if it sends power out when it is actuated. Also, here is a how to for reprograming the fob. See if it helps.
https://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm
Feb 3, 2010 at 9:21 PM
CHERNANDEZJEEP
[quote:5524b1d123="Jacobandnickolas"]You need to check the main switch on the driver's door. Check to see if it sends power out when it is actuated. Also, here is a how to for reprograming the fob. See if it helps.
https://www.2carpros.com/how_to/how_to_reprogram_key_remote_fob.htm[/quote:5524b1d123]
Which would my jeep fall under GM receiver? Also at high speeds my car starts to vibrate from 50-60mph and then sometimes when I hit a bump at those speeds it will set off my front tires to where they go crazy like im running over a million speed bumps and my steering wheel goes crazy with it. It isn't until i slow down to about 30 that it stops and slowing down that much on an interstate is dangerous.
Feb 4, 2010 at 12:41 AM
Chrysler
Have the pitman arm and all steering components checked for the vibration.
Feb 4, 2010 at 7:54 AM
CHERNANDEZJEEP
[quote:6c75b0b0ad="Jacobandnickolas"]Chrysler
Have the pitman arm and all steering components checked for the vibration.[/quote:6c75b0b0ad]
What is a pitman arm? and the link that you showed me only has GM, Ford, Blazer, and Honda sliding door. =[
Feb 4, 2010 at 11:39 AM
