1999 Jeep Cherokee electric fan
1999 JEEP CHEROKEE
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
MPMD1109
electric cooling fan runs all the time, even when engine is turned off. Doesn't matter if engine is cold or hot.
Dec 13, 2009 at 10:20 AM
JDL
  • 16,098 POSTS
welcome to the forum, there should be a fan relay in the power distribution center. Pulling the relay should kill the fan? If you have a digital multimeter or led testlite, you can check voltage circuit at the relay. Voltage to load side of relay is hot all the time. Voltage to coil side of relay, goes hot with the key on, That circuit should not be hot with the key off. Also, the pcm controls the coil ground in order to energize the relay.
Dec 13, 2009 at 2:29 PM
