1999 Jeep Cherokee Break lights
1999 JEEP CHEROKEE
134,000 MILES • V8 • 2WD • AUTOMATIC
KIMMOY
My driverside break light shines bright while my headlights are off, or the vehicle is off. When i turn the lights on and apply the break pedal my brake light goes off. The bulb works, the fuse is not busted, and the passenger side is fine . Where could the problem be?
Mar 2, 2010 at 9:15 PM
CJ MEDEVAC
  • 11,004 POSTS
see my profile.......this is a general way to check your or similar light issues.....this particular one was a signal light on another vehicle.......answer to another one of my facinating posts.
Tell me if I help......like that "BACK PATTING"
PASTING.......
POSSIBLE HELP ??!!--------See my profile--------
INSURE your bulbs (all that may be involved) are all the way in..... CORRECTLY!!!! (NOT just jammed in any old way)-------
If NO-GO-------run temporary jumper from NEG GRD BATT to-------- housing/ NEG on wire/ to bulb/ touch GRD screws/ etc. that would ground that system---
TOUCH ONLY-ONLY-ONLY GROUNDS !!!!!!!!!!......If one of these operations makes it work........Repair that problem.(GROUND)......Like I said, "POSSIBLE HELP"
Love, Turddog
Mar 2, 2010 at 9:29 PM
