This jeep has 3/4 ton ford axles and brakes under it, with 37" tall tires.
Brake pads, calipers, drums, rotors and brake lines are new. Master cylinder is supposedly new. My problem is, the brake pedal will randomly fall to floor when braking. It will not do it unless you back out of a driveway or a parking spot, then go foward. As the pedal falls the brake light will come on. After pumping brakes a few times the light will dissapear and brakes work normally.
I have had brakes blead several times and no leaks are present in the lines. I give up! I have had a few brake shops try to diagnose the problem and it remains a mystery! please help, this thing is a tank and I dont want to run and cars over
Jan 7, 2010 at 12:12 PM
