1999 Jeep Cherokee
1999 JEEP CHEROKEE
10,475 MILES • V8 • AWD • AUTOMATIC
JIMBOB4550
what is the remedy for no heat on passenger side only,is it because the door is stuck closed?is it because there is a vacuum leak what can i do to repair this problem?
Feb 1, 2010 at 10:52 AM
It sounds like you may have hit the problem. The vent doors are actuated by vacuum. Chances are you either have a stuck door or a vacuum leak (which is most likely). Check under the dash for leaks. With the engine running you may get lucky and hear a hissing sound from the leak.
Let me know what you find.
Feb 8, 2010 at 11:53 PM
