Transmission problem
1999 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
i have a 99 jeep grand cherokee and i installed a used transmission and it will not change out of first gear unless i remove the battery cable to clear the check engine light and then it will drive and change out normally until i turn it off then it will go back to being stuck in first.the code p0720 comes up but i replaced the output speed sensor and it still do the same does not change out until unlessing i clear the check engine light what could this be
May 13, 2010 at 9:00 PM
