1998 Jeep Cherokee Wet Floorboards
1998 JEEP CHEROKEE
112,000 MILES • 6 CYL • 4WD • AUTOMATIC
JNERD780
My '98 Jeep Grand Cherokee Limited, the floorboards become soaked when I run the a/c. It is damp on the drivers side but much worse on the passenger side front and back. I'm not really too sure where the line is running for it to drain correctly. Is there an easy way to solve this problem or am I in for an expesive headache?
Thanks,
Jake
May 26, 2008 at 1:55 PM
MERLIN2021
  • 17,250 POSTS
Get under the Jeep look on the passaenger side where the A/C plenum meets the firewall, at that spot, use a piece or wire and clean out the drain hole, don't go too deep or you may damage the evap core...The other problem could be the windshield needs more sealant around the glass.
May 26, 2008 at 1:59 PM
