When I start out, my Jeep doesn't want to shift from 1st to second gear unless I back off on the accelerator, then it shifts into second. All other gears shift normally.
I've tried shifting manually and the same problem happens. When I move the shift lever from 1st to second the car stays in 1st until I back off the accelerator.
This happens whether the car is cold or warm. No previous maintenance was performed on the vehicle prior to this problem and the transmission fluid was changed within 5000 miles.
Thanks,
Steve
Thanks,
Steve
Mar 21, 2008 at 9:31 AM
