1998 Jeep Cherokee SENSORS
1998 JEEP CHEROKEE
141,000 MILES • V8 • 4WD • AUTOMATIC
RWELLINGTON
HOW EASY IS IT TO CHANGE A SPEED SENSOR?
HOW EASY IS IT TO CHANGE FUEL INJECTORS?
HOE EASY IS IT TO CHANGE A THROTTLE POSITION SENSOR?
WHERE ARE THEY?
May 19, 2008 at 7:01 PM
BLACKOP555
  • 10,386 POSTS
THrottle position sensor is on the throttle body and if you dont install it properly you will be having problems with it, a few thousands of and inch off can affect you greatly.
the fuel injectors are located in the fuel rail and they will require removing the intake manifold to get to them all.
speed sensor is near the trans and that will be a decent task to do.
May 19, 2008 at 7:41 PM
