1998 Jeep Cherokee CODE P0783
1998 JEEP CHEROKEE
100,195 MILES • 6 CYL • 4WD • AUTOMATIC
SNAND
CODE P0783 - 3-4 Shift Sol - No RPM Drop at Lockup
Is there a fix for this problem without breaking the bank?
Jan 9, 2009 at 10:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I would suggest checking the ATF (automatic transmission fluid) level and condition of fluid first. If this is okay then the tranny will probably need to be repaired or replaced. The shift solenoid is an internal component of the tranny and usually costs around $1,000 to have the job done.
Thanks for using 2carpros.com!
Jan 10, 2009 at 2:02 AM
