1998 Jeep Cherokee Chattering and pulling to the left
1998 JEEP CHEROKEE
142,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEDMONDSON
I had replaced the brake pads and rotors on the front. Also replaced the front right u-joint. Now while braking it pulls to the right and makes an awful grinding, whining and clicking sound. I did notice that while replacing the u joint that the gear for the speed sensor was cracked and chipped. Could this be the cause? If so how do you replace the gear and sensor?
May 7, 2010 at 8:49 AM
Are you refering to the stator? Also, are the rear brakes properly adjusted?
May 20, 2010 at 11:06 AM
