1998 Jeep Cherokee 4x4 80,000 Broken Driveshaft
1998 JEEP CHEROKEE
SCOTTTHEHOTTY
  • 4 POSTS
Last summer I tried to pull out a jetski from the lake on sand. I have command trac 4x4 and had it in low gear. After I backed up I put the parking break on and then accidenlty left it on when I put in into drive. The drive shaft twisted and broke into two.
I replaced the drive shaft but now I have terrible vibrations above 70mph but below 70 everything is smooth. Did I do damage to something besides the driveshaft?
Feb 16, 2007 at 11:36 AM
CHEVY22
  • 1,375 POSTS
is it a two piece drive shaft ?? with a carrier bearing in between??lmk
jim
Feb 16, 2007 at 4:25 PM
SCOTTTHEHOTTY
  • 4 POSTS
There is a short piece that hooks into the transfer case then connects with a uv joint to the main drive shaft. From the drive shaft there is another uv joint that connects to the rear differential.
I took off the front drive shaft and the vibration and loudness is only slightly less at 70mph+.
Anything under 70 is not noticeable.
Feb 18, 2007 at 2:55 PM
CHEVY22
  • 1,375 POSTS
THATS PROBABLY IT THEN , AS FAR AS OVER 70 GET THE TIRE BALANCE CHECKED,
THANKS
JIM
Feb 18, 2007 at 4:20 PM
SCOTTTHEHOTTY
  • 4 POSTS
The noise and vibration is worst when accelerating and is much less when deaccelerating or constant.
I just had new tires put on.
Feb 20, 2007 at 8:44 AM
CHEVY22
  • 1,375 POSTS
was the problem there before the new tires ??, i didnt know that before
Feb 20, 2007 at 10:18 AM
SCOTTTHEHOTTY
  • 4 POSTS
Yes. I didn't have any high speed problems till I broke the driveshaft.
Feb 20, 2007 at 10:43 AM
