Did you check primary voltage at the coil, engine cranking, dark green wire with orange tracer should be hot? The same circuit supplies voltage to the injectors and 02 heater circuit as well.
Can you check for codes? Do you have digital odometer? If not, you should be able to get some mil codes, if there are any? You cycle the ignition switch, on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. You cycle the key just till the dash lites come on, no further.
Dec 7, 2020 at 12:19 PM
(Merged)
