1996 Jeep Grand Cherokee Transmission Problems Maybe??
1996 JEEP CHEROKEE
THELIZARDKING8875
I have a 1996 jeep grand cherokee V6 with 170k miles on it. Whenever I drive it for about an hour without stopping(besides redlights and stop signs) it will start revving high and it doesn't want to go into 4th and 5th gear easily. The longer I drive it the worse it gets. Eventually it will automatically go into overdrive and i cant take it out of it. After that it will soon shut down and the in-cabin computer will say "trans. over temp." My mechanic said the transmission is fine. Is it a computer problem?
Mar 26, 2007 at 1:31 PM
MERLIN2021
  • 17,250 POSTS
Well...if the tranny is cooled by your radiator, try an aftermaket tranny cooler...
Mar 29, 2007 at 5:15 PM
THELIZARDKING8875
How do I know if it is cooled by the radiator? And what is an after market transmission cooler?
Mar 29, 2007 at 5:45 PM
MERLIN2021
  • 17,250 POSTS
If ya gotta ask...maybe someone else should do it for you! If you cause a tranny leak, the fluid will be on the road behind you in 1 mile...That said...if the rad cools the tranny, there will be 2 steel lines bolted into the radiator... if there are 2 lines...usually rubber going to a small radiator in front of the big one then disregard!
Mar 29, 2007 at 7:59 PM
