1996 Jeep Cherokee WILL NOT SHIFT TO 4TH
1996 JEEP CHEROKEE
MK1926
  • 4 POSTS
Transmission problem
1996 Jeep Cherokee 6 cyl Two Wheel Drive Manual
WHILE DRIVING CAN NOT SHIFT TO 4TH. GEAR , BUT WHEN PARKED I CAN SHIFT TO 4TH GEAR.
CHECKED TRANS OIL, LEVEL CORRECT.
THANK YOU
ML1926
Nov 18, 2009 at 11:15 AM
KHLOW2008
  • 41,814 POSTS
Hi MK1926,
Thank you for the donation.
Symptom indicates a bad 4th synchronizer hub or excessive clearance between the gear and hub. This could be due to worn synchronizer ring or a worn clutch shaft bearing and you would have to disassemble the trans to check/repair problem.
Nov 23, 2009 at 8:00 AM
  • 35 POSTS
It has to be in neutral to get into 4 low
Dec 9, 2009 at 5:11 PM
