Location of Fuel Pressure Regulator
1996 JEEP CHEROKEE
JIMZER
Hey there
I have a 1996 Jeep Cherokee SPORT. I can't seem to find where the FPR is located. Is it inside the tank with the fuel pump, and, if so can I replace the FPR without having to replace the new pump? The pump is only a couple of years old, but I didn't install it myself, so I don't know.
Jun 28, 2010 at 4:36 PM
SATURNTECH9
  • 30,869 POSTS
The Fuel Pressure Regulator can be replaced...it's located on the fuel pump assembly (in the tank), but can be replaced without purchasing a whole new pump assembly. Some say you can do this without taking the tank down but the manual says you do.
Here is a diagram to help show you how.
Cheers
Jun 28, 2010 at 4:43 PM
JIMZER
Yep, thanks for the guide and diagram worked perfect I took the tank down though I can see that you can get your hands in there to do the job if you had too.
Jun 28, 2010 at 4:54 PM
JEEPSOS
The following post was displayed on June 28, 2010, and I would like to get the FPR info. From my understanding, it is hard to find the correct FPR for this vehicle. Opinion question for you: If you have to drop the tank to replace the FPR, why wouldn't a professional mechanic who has been around a while not recommend doing this at the same time the pump is done? It is an expensive labor job. Just curious. Here is the previous post:
Question:
Hey there-
Answer:
The fuel pressure regulator is part of the fuel pump module and not able to replace it by itself.
Additional Answer
Yes that is correct I emailed you the information on your fuel pressure regulator to your personal email.
If I could get that info, it would be very much appreciated. It was answered by saturntech9.
Jul 11, 2017 at 12:35 PM (Merged)
HMAC300
  • 48,601 POSTS
if there were no code then he wouldn't replace it looking at rock auto I see a fuel pressure regulator but looks like it goes on rail96 doesn't show a internal fuel pressure regulator but 97 does so it would maybe depend on build date of vehicle. and 97 you can get a pump or the module. so it really depends if engine light was on or not. if not then he wouldn't replace it.
