1996 Jeep Cherokee
1996 JEEP CHEROKEE
BLACK_SHEPER
1996 Jeep Cherokee
This morning I had a message that said CHECK GAUGE. So I pulled over and opened the hood and out came all this smoke. I barely came home and am not quite sure what to do?
Feb 9, 2009 at 9:04 AM
ALANBIG6
  • 9 POSTS
the smoke from under the hood if it had a sweet smell its coolant , check all fluid levels and see if any are low . dont open the radiator cap when the engine is hot .....if the coolant is low you will need to look for a leak possable water pump leak or hoses . its best to use a pressure test to check the cooling system .
Feb 9, 2009 at 8:50 PM
CRZYDRVR
  • 432 POSTS
it could also be an alternator or a battery issue. look at you voltage guage when its running. Voltage should be around 14.0
Feb 18, 2009 at 2:19 AM
