1995 Jeep Cherokee leaf springs
1995 JEEP CHEROKEE
JEFF BABCO
Suspension problem
1995 Jeep Cherokee
how do you install them
Jul 25, 2009 at 7:40 AM
Are you refering the entire unit? If so you will need to lift the vehicle from the frame (not the axle). THere are two large u-bolts around the axle that connect it to the spring. REmove them, remove the bolts from the shackles and reverse the order to replace. NOTE: Spray everthing down with penitrating oil a few days before starting the work. THe bolts usually don't like to cooperate.
Jul 26, 2009 at 10:51 PM
