1995 Jeep Cherokee anti/theft Security
1995 JEEP CHEROKEE
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVIDMEATMAN123
i disconnect my battery and i change my starter and connect back the battery and try to started and the start made a loud nocies all the lights and Security started flashing
how can i fix this
Jun 20, 2009 at 6:02 PM
MERLIN2021
  • 17,250 POSTS
If everything was ok electrically before you did the starter, explain what steps you did to disconnect, then reconnect the starter?
Removal & Installation (Cherokee & Wrangler - 4.0L) Disconnect negative battery cable. Raise and support vehicle. Disconnect battery cable and solenoid feed wire from solenoid. Remove starter lower mounting bolt. Remove starter upper mounting bolt and remove starter. To install, reverse removal procedure. See TORQUE SPECIFICATIONS . Removal & Installation (Grand Cherokee - 4.0L) Disconnect battery negative battery cable. Raise and support vehicle. Disconnect battery wire and solenoid feed wire connector. Remove starter front mounting bolt. Remove starter rear mounting bolt and remove starter. To install, reverse removal procedure.
Jun 20, 2009 at 7:01 PM
DAVIDMEATMAN123
First we disconnected the batter cables. Second we disconnected the solenoid cable and then took off the two bolts that hold it on. Then, I put the new starter on. I connected the bolts first and then the solenoid cable. Finally I reconnected the battery cables, and I am not sure which one was connected first, the positive or the negative.
Jun 22, 2009 at 6:11 PM
MERLIN2021
  • 17,250 POSTS
OK try this, dissconnect the battery cable in this order, negative, positive, now clean BOTH cable ends and bettery posts, they have a special brush to do this... now attach the positve then the negative and let me know what happens. Now one other question, did ANYTHING spark when you worked on it?
Jun 24, 2009 at 1:35 PM
