when i shift in 4x4 it's sluggish driving when i go back to 2 wheel it has a whine/grind noise what could cause that problem
Mar 4, 2010 at 10:17 AM
CERTIFIED EXPERT
Can you tell aprox where the noise is coming from?
Mar 4, 2010 at 10:30 AM
GREEZY2010
MEMBER
it sounds like the 4x4 is not disengageing all the way
Mar 4, 2010 at 10:37 AM
CERTIFIED EXPERT
Two questions. Does it sound like the transfer case or the front axle that isn't disengaging? Also, have you checked the linkage to the transfer case?
Mar 4, 2010 at 11:49 AM
GREEZY2010
MEMBER
it sound as if the front axle is whinning when you shift out of 4x4 also when its in 4 wheel high the trucks seems to not want to pull correctly
Mar 10, 2010 at 11:04 AM
CERTIFIED EXPERT
If the 4wd isn't disengaging, to me it sounds like one of the hubs isn't turning off. The front hubs are actuated by vacuum when you place it in 4wd. If the hub is dirty or damaged, it may engage and then not disengage. When you say it isn't pulling correctly, it makes me believe there is one side that is sticking.
