Under the dash where the switch is located, there is a button on the side. Push the button while you pull out on the switch. The knob should pull the entire way out. Once it is out, you will have access to a nut that holds it in place. Loosten it and remove the switch from the rear.
Sep 8, 2009 at 8:26 PM
