1994 Jeep Cherokee I have cruddy brakes.
1994 JEEP CHEROKEE
226,769 MILES • 6 CYL • 4WD • AUTOMATIC
MYJEEPISJUNK
So i replaced the lines, master cylinder, bled the lines and made sure everything is tight with no leaks. I can pump the brakes up and get resistance but the pedal normally goes to the floor, what am i missing here?
Sep 29, 2010 at 12:16 PM
MULDOON
  • 79 POSTS
Where did you get the Master Cylinder from it may be defective, Declan.
Sep 30, 2010 at 7:57 AM
MYJEEPISJUNK
I know its not the cylinder because I put one that I know for a fact works, I'm thinking maybe there might still be some air in the lines even though i cant see any air coming out when i bleed them.
Oct 1, 2010 at 9:06 AM
MULDOON
  • 79 POSTS
Are you getting a good stream from bleeding, Declan.
Oct 1, 2010 at 9:11 AM
MYJEEPISJUNK
yes, everything went fine when changing the parts and bleeding the system, i'm thinking there might be a air bubble in the system that just wont come out.
Oct 2, 2010 at 9:04 AM
MULDOON
  • 79 POSTS
If you think there is air you will not get a steady stream of fluid, how does the brake booster work, Declan.
Oct 3, 2010 at 10:04 AM
AJPANDA1
Did you get it sorted I have same problem, and have done everything you can think of replaced everything bleed everything and systems but still goes to the floor !! It all good then suddenly nothing and then they back!
Nov 15, 2012 at 3:44 AM
