1993 Jeep Cherokee engine knocks
1993 JEEP CHEROKEE
120,000 MILES • V8 • 4WD • AUTOMATIC
ANGELROSARIO
engine knocks, added protech drygas, knocking stopped for a little while, knocking returned.
possible solution?
Feb 22, 2009 at 12:52 PM
Hi:
Does this sound more like a bearing knock or a ping while under a load? Does it happen all of the time or only under certain conditions?
Feb 22, 2009 at 2:10 PM
ANGELROSARIO
[quote:bb880facb9="Jacobandnickolas"]Hi:
Joe[/quote:bb880facb9]
no ping, motor rattles a little then knock, rattles a little then knock. happens more in idle than when driving, but happens in either case
Feb 22, 2009 at 9:01 PM
The only thing I can say with a knock is that it is usually a bearing problem (rod, main, cam...). Make sure the oil is full and that you are using the proper weight.
Feb 23, 2009 at 9:23 AM
