[quote:5fdb0ab7f3="sdnzoo"][quote:5fdb0ab7f3="BMRFIXIT"][quote:5fdb0ab7f3="sdnzoo"][quote:5fdb0ab7f3="BMRFIXIT"][quote:5fdb0ab7f3="sdnzoo"]Electrical problem
1993 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 217000 miles
My '93 Jeep Cherokee is over charging. The gauge is correct and the ECM has been replaced. I have even replaced the alternator. I know Chrysler voltage regulators are in the computer so that's where I started. The alternator was original so I replaced it also. Any guesses? Thanks in Advance.[/quote:5fdb0ab7f3]
just a suggestion did you check the battery[/quote:5fdb0ab7f3]
I have replaced the battery three times now. I should have mentioned that before. Sorry.[/quote:5fdb0ab7f3]
what is the running volts did you check it at the battery if possible use a digital meter
i will try to see if there is any TSB on it[/quote:5fdb0ab7f3]
It is between 15.63 and 16.95 at the battery. I appreciate your help.[/quote:5fdb0ab7f3]
do you have a scanner tool ?
if so you can do a field test
did you check for codes stored
check wiring between alternator and car module
Jan 29, 2008 at 1:46 PM
